North7
North7
North Texas
SUV
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
I just got confirmation that my 2021 Badlands non Sasquatch is in production. I ordered a 3.5" lift kit and then received a phone call that it will not fit and that there is no lift available for the Badlands models yet. My intentions were to put 37's on it but now I am not sure where to start at.
Does anyone have a link to lift kit that will work with a non SAS BL?
THANK YOU - I also work for a dealer if you need anything.
I’m curious as to what their reasoning for it not fitting is.
If it’s a spacer lift, and it’s meant for lower trims, the BL suspension may allow for too much travel.
If it’s a spacer lift meant for Sas, then it may work with BL but just not provide the advertised amount of lift.
If it’s a full coilover replacement, then it should work, since you’re just removing all the BL components from the vehicle anyway… maybe they just haven’t tested it so they don’t want to say it will work?
Were they more specific?
RyanJ007
Ryan
Maryland
Tesla Model S, 2021 Bronco
Ordered a Zone 3.5" spacer lift - I was told they have one for Sas and standard but not Badlands. The Badlands is in R&D and may be available in the future months to come. There is a ton of conflicting information on this topic all over this site and other forums. I am going to get a 1" spacer that I know fits and is available until someone has a definitive lift option available.
North7
North7
North Texas
SUV
In stock TODAY, in Maryland...
https://www.4wheelparts.com/p/4-whe...front-coilovers-52233bx-1/_/R-4WPBR-52233BX-1
Ford Bronco The Definitive Guide to 2021+ Bronco Ride & Lift Heights with Wheel & Tire Sizes 1636556003501
Ford Bronco The Definitive Guide to 2021+ Bronco Ride & Lift Heights with Wheel & Tire Sizes 1636555955066
North7
North7
North Texas
SUV
@flip, one of the forum Ford dealers (aka, one of the good guys) is collecting VIN's so he can put together a list of Ford part numbers for the Bilstein coilover assemblies so forum member will be able to order a full assembly from him to upgrade their suspension to either Badlands or Sasquatch style coilovers.
Please follow the below link to his thread and DM him your VIN number so he can build a complete picture of all variables and options, which affect spring part numbers.
Need VINs for suspension IDs
flip
Phil
IN
www.ruxerparts.com
Fords
I do need these to be vehicles that have been built and delivered. The parts systems has some lag built in loading vehicles so if you've taken delivery, it should be in there.
66Fan
Tim
IL
2022 Wildtrak
Just a guess, but I would imagine it is due to the sway bar and electric disconnect. IIRC, it is frame attached and they likely didn't account for the extra travel needed for the sway bar and its electronic disconnect/connect mechanisms/wiring. Mechanical sway bars are easy and/or may not need to be moved at all. The electric on probably gets finnicky once the geometry is jacked with.
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
I like this reasoning, but looking at the frame and how the swaybar is connected/mounted, I don't think this is the issue... not to mention both the Sas and BL can come with disconnects... so it's not a problem unique to the BL.
mpeugeot
Is there anyone we can waterboard to get the spring rates?!?
mpeugeot
GreenMtnBronco
West Nyack NY & Central VT
'21 BadSquatch; 13 Wrangler JK; 04 Lifted Mini
You would want a 3" lift on a non-squatch Black Diamond for 37" tires. You may also need new upper control arms for that as well so you don't damage your CV joints. This really needs to be new coilovers, not spacers. Other threads show other possible solutions to lifts and 37" tires, but it depends if this will be a off-road beast or mall crawler queen.
Fender flares are personal preference and what wheel offset you go with (many other threads discuss this part of the equation). But general rule of thumb, you want wider fender flares so you don't chip up the side of you Bronco, the door handles and the windshield of the person following you.
this chart confuses me. if you are replacing suspension completely for 37s, why would you need a shorter coilover on the Squatch vs other trims? once the coilover is removed aren't we all starting from the same mounting position? I get there will be some weight differences, but it seems like once I pull the suspension, i have the same clean slate regardless of trim.
what am I missing?
North7
North7
North Texas
SUV
what am I missing?
Technically you're correct we all starting from the same mounting position, however there are no starting dimensions for that. My dimensions start from Ford's documents and make and analysis from those for each trim.
Regarding "why would you need a shorter coilover on the Squatch vs other trims?" You don't, you need less lift, due to tire size. Starting from the overall tire diameter, you take one half of that to determine how much lift each size tire gives you, I call this Radius Lift, shown in the below chart.
Then you move onto this chart which shows the amount of total lift you need, including both Radius Lift and taller Coilovers or Spacers, by trim.
GreenMtnBronco
Ford Bronco The Definitive Guide to 2021+ Bronco Ride & Lift Heights with Wheel & Tire Sizes 1623678791332-
@North7 - Right! hadn't thought about that, but my concern is in true offroad conditions, if I do a suspension lift of 2.0" on a BL Squatch to accommodate 37s, do I risk any rub at full compression?
at say 2.0 or 2.5" of total lift, do I need to worry about geometry and replace the UCAs?
NaturalFlorida
Dale
Vero Beach
1985 4Runner SR-5 / 7" lift / 5.29 Gears / Lockers
https://www.iconvehicledynamics.com/accessory/17743/icon-accessories-21-up-bronco-3-c-o-spacer-kit/
