TrailRax
TrailRax
Lux Sponsor (Level 2)
TrailRax
Woods Cross, Utah
www.trailrax.com
2023 Bronco Badlands
thank you. love the communication coming from trailrax. including the pro-active emails to customers. 💪👍
We definitely put our customers first and make sure communication is our biggest priority.
doyouglas
Douglas
Southern California
Toyota Highlander
Are we able to fit any universal 40" lightbar for the cutout fairing or is it only exclusive to the heretic 40" LED lightbar.
TrailRax
TrailRax
TrailRax
Woods Cross, Utah
www.trailrax.com
The cut-out is roughly 42" wide. It should fit most 40" bars but may mount differently. Also, the engineering around the Heretic bar gives the user so many benefits which are why we recommend them. The standard mounts that come with the Heretic bars fit perfectly as well, other brands may be different.
TrailRax
TrailRax
TrailRax
Woods Cross, Utah
www.trailrax.com
@TrailRax Sorry if I missed an update… was there an ETA for the standalone PaxRax for the 2DR?? Or the Half Rack + PaxRax?
As of now, a 2-door stand-alone Pak Rax will not be possible since the 2-door only has one clamp location in the rear. It would require drilling for a stand-alone which we assume will be highly unpopular. We are continuing to look into the issue for a solution but it is not looking to be possible. The 4-door model will be the only model we currently plan to produce a stand-alone pak rax to work on.
Boreal
Colby
MB
www.cspencephoto.com
2022 Badlands 2DR
Shame about the solo PaxRax, but I understand the design constraints.
Is the 2DR Half Rack + PaxRax still in development?
TrailRax
TrailRax
TrailRax
Woods Cross, Utah
www.trailrax.com
Same situation. With only 1 clamp per side on the Bronco 2 doors, the front 3/4 of a proposed half rack would just be free floating. This again will require drilling or another option that we could see damage down the road with just through vibrations and weight load.
The 2 door options from us right now are full length, with or without pak rax. Sorry. We are doing what we can behind the scenes to see if we can find solutions, but as of now, we do not have a solution coming soon.
jaeggernaut
BMW M Coupe // Volvo P1800S // Caterham CSR 200
i don't know how ford messed this one up. the rear 1-pc section of the 2-door hard top is actually longer than for the 4-door. why they didn't add a 2nd attachment point on the 2-door is baffling.
TrailRax
TrailRax
TrailRax
Woods Cross, Utah
www.trailrax.com
It sucks, we have played with a lot of ideas and we may be able to solve the issue but it will not hold a ton of weight which will result in tons of more customers going for the full-length model over the half-length. Our full length still offers the ability to remove the front panels with ease, it also decreases heard wind noise on the vehicle, and its capacity rating is 850 lbs (static, evenly distributed).
Rednek
Jimmy
Northern Alberta
Hmm just went to pre purchase a 4dr rack and it kicks me out as sold out?any way to get on a wait list(it's a Bronco thing lol)
TrailRax
TrailRax
TrailRax
Woods Cross, Utah
www.trailrax.com
Weird! It may be that the variant you selected is sold out. There are a lot of units that have already sold for the incoming inventory coming in. If you want one of as soon as possible, a different variant needs to be chosen.
Rednek
Jimmy
Northern Alberta
There we go had to order without pakrax,can they be purchased later?
TrailRax
TrailRax
TrailRax
Woods Cross, Utah
www.trailrax.com
Yes absolutely! That will become available shortly, also you can upgrade your wind deflector as well. I think our inventory still shows some 4D, standard deflector, and pak rax still available. You can later upgrade the deflector. Either route works.
Rednek
Jimmy
Northern Alberta
GREAT! only thing is discount code don't work
