mmcq
For what it’s worth, I did air down to 13psi in all tires while riding the dunes. Back up to 39psi for the trip home. Airing down (or not) shouldn’t have any impact on the engines ability to run though.
I have a question concerning GOAT. The OP stated they were riding sand dunes before the engine failed. I am guessing they selected a GOAT mode while running the dunes. When in dunes with our 4x4 vehicles, we pressure down the tires to 15-20 pounds in order to improve traction and not damage drive trains. Regardless of GOAT mode selection, wouldn’t tire pressure reduction still be required? Could not reducing tire pressure while in the sand have something to do with this engine failure? Just asking thanks.
mpeugeot
But did you wax the engine?
MayhemMike
Mercury
Thanks, I was wondering about airing down. I do however disagree with “ airing down or not, the engine should be able to run through”. I have witnessed my fair share of off road vehicles that caught fire and burned to the frame because they were run through the sand without airing down. And I am only speaking of ocean sand dunes. Glad you have your Bronco back. It looks fantastic.
Beachin 74
Delaware
Normally I would have called BS on that statement until I seen it in person. 😲
Watched this guy get stuck on the dune crossing from about 800 yards away in an Explorer. For some reason the guy panicked and kept revving the motor spinning his wheels until it caught fire and burned to the ground.
Happytown
Ryan
Zachary, Louisiana
2013 F150 Eco SCREW 4WD
Why does this happen?
Beachin 74
Delaware
From what I seen, inexperience and panic.
When your tires start to dig, STOP. Air down more, get the strap out, or get the shovel and start digging.
omega145
Rubicon Recon
I think he meant, why does the car catch fire? At least that's what I'm wondering.
Did some Googling and found some similar situations related to over revving causing overheating in different situations:
https://www.fox23.com/news/breaking-news/revving-engine-spinning-tires-cause-fires/254364633/#:~:text=All the revving, shifting gears,Fire Department Spokesperson Tim Smallwood.
https://www.nbcnewyork.com/news/loc...-suvs-engine-while-stuck-in-snowbank/2866311/
https://www.carscoops.com/2019/07/c...ngine-until-it-blows-up-and-erupts-in-flames/
