Wildtrak vs. Badlands + Sasquatch...
SouthernBronco6g
Georgia
Mustang
Assuming all models have drain plugs, carpeted or not? so you could line x your floors and remove carpet?
They don’t, some have the rubberized flooring with drain others do not. Just like you can’t get the sway bar disconnect on the Wildtrack or the bash bars.
or get a manual below a certain trim. It did look like however 2.7 ecoboost was optional on all.
BroncoBoy22
Laker Land
'11 Mustang GT 5.0
Wondering the same thing. Between the badland and the wildtrak
I really want the black hard roof, and the 35s. I guess it really comes down to how much the mid-pack is and how much the sasquatch is
My perfect would be badlands with hard black roof, sasquatch and lux pack
Edit: with the 2.7L V6
Same! I think we have to wait until the configurator is up
broncoSJ
2021 Ranger
Just heard from my dealer on switching models. I may switch from badlands to wildtrack depending on option prices. See his comment below.
Also, they will honor x pricing
From dealer -
We generally do not mark up any vehicles above MSRP. The only exception is the Ford GT 350, 350r and 500.
Raptor’s are at MSRP, and all the Bronco’s will be at MSRP also.
As of right now I do not have an option to swap orders. Ford is recommending placing a second order for the other trim level and cancelling an order once we move to the next phase.
Whec716
Houston
Subaru
Yes, I am going to daily drive it. I do not really have to, but I enjoy driving a fun daily driver :) I bet the gas mileage will not take too big of a hit.
2.7 f150 gets 20 and 26mpg
Longshot
Nick
2016 F-150
With the A/C off and driving 65 you could probably hit 26... I get 22-23 avg mixed with an extended cab 2wd... But I usually drive 75 on the freeway... Not complaining at all, just adding info... I would guess the Bronco might be a bit lower due to tire size, but still better than teens...
JJBulldawg
Jayson
Middle Georgia
2018 F-150 Lariat, 2006 Harley Ultra, 2021 Bronco
I'm from Texas as well and I originally ordered the Wildtrak but will be switching to the Badlands for a couple of reasons.
1) Badlands comes with armor and steel bumpers - Wildtrak does not
2) Badlands comes with a couple more drive modes -
3) Wildtrak doesn't advertise that it has drain plugs nor the vinyl seats - I prefer both.
4) Badlands has the front disco sway bar. No mention of the Wildtrak having it.
4) Wildtrak is a grammatically incorrect spelling - sounds/spelled too hipster for me.
2.7 Badlands with Squatch and Lux for me. Add rock rails and it's pretty well sorted from the factory and 100% under warranty. Dealer can't even complain that your bigger tires caused ball joint issues!
Wildtrak almost seems like a pre-warthog (raptor Bronco) but not really.
100% this. To the letter. Reserved WT, after further thought want Badlands for all those reasons, drains, marine grade interior, dico. But the 35s and 2.7 are important. Not sure what that does to pricing.
FellowM3
Northern NJ
Current: 22' Braptor, 2020 BMW M340
guessing 2.7L is $2500, hard top is 2500. sasquatch on badlands is 2200... (less expensive than on other series because badlands already has the rims and 33" tire)
Lux package from a mid package is quite likely a chunk of money too. on a raptor, the B&O audio plus 360 cam is $10k.
This is what I am afraid of. This makes me realize this car may be very over priced.
For a badland trim, with a 2.7L engine, sasquatch package, hardtop, and either Hi or Lux pack, this thing is most definitely hitting that 60K mark. And that's without leather. This is a bummer.
cpmont
Charles
Huntsville, AL
1999 F150, 1997 Mercury Mountaineer
Does anyone know if you could change your reservation from a badlands to a wildtrak for example?
When you place the real order you can order which ever one you choose. I'm guessing the reservations are just for planning and marketing.
OpenAir25
MA
That is pretty good, if it is in that ballpark that would be fine.
FellowM3
Northern NJ
depends what you compare to I suppose. I can get a rubicon to 54k but its still missing things from the badlands+sasquate+lux. The rubicon really has no answer to the sasquatch package, not the wheels or the suspension. I think this alone can explain the remaining 5k, but their powertrains are a bit inferior as well. Their hard top is not remotely as dynamic. easy to pour through the rest of it and find shortcomings in the wrangler, screen size, interior, transmission (unless you want a 6sp with a V6, then wrangler has the high ground, but Id take the drivetrain from the F150 over any auto FCA offers)
Not saying its cheap... but I wouldnt say its "over priced".
I was more hoping that the pricing for the Bronco wouldn't be neck and neck with the wrangler. I am not a wrangler fan, I hate how they drive, but I was more hoping Ford would be a bit cheaper than the wrangler at least at first to start to steal that market share
NorthernBronc
Dylan
Canada
335xi
Reserved a Wildtrack but very torn due to floors on the badlands. Can't wait to see pricing once the configurator arrives.
evoaire
Evoaire
VA
maybe a bronco
When ordering a badlands, and adding the squatch, is that installed at factory or dealer?
GravyTrain
Greg
Oklahoma
LR4, 2020 110
How do you know this? Are you assuming because it doesn't specifically list the drain plug?
