Manual transmission scraping noise / grinding sound
PWillette
Parrie
Maine
thanks, i actually know this problem well, i also had a previous Bronco Manual with the same noise. My question was more about replacing the clutch since the whole trans would already be apart and the clutch is a normal wear item similar to brake pads. The clutch wouldnt be covered but since its already out i am assuming all id pay is the price of the clutch no extra labor.
Most likely there would still be a small labor charge for the clutch work.
If I get to this point, which I'm sure is just a matter of time, I'll be replacing mine during the TSB, as well as the flywheel, as a matter of upgrade, not so much a need.
tomo56
TK
USA, Georgia
2020 - 4Runner, 2021 Tundra SRS, 2023 Bronco
Do you have a link that you would not mind sharing to the upgraded parts you plan on installing during the TSB?
PWillette
Parrie
Maine
Not at the very moment, do a search on Southbend clutch. Few threads should come up.
Begster
Boston
22 Bronco
Every time I've asked a dealership about replacing something while they already had it apart for a warranty issue on other vehicles (clutch disk when they were warrantying the pressure plate, brakes, serpentine belt when they were replacing idler pulley, etc), I've been quoted almost full price as if they wouldn't already have the stuff removed.
cpmartin1999
chris
Atlanta
2022 Badlands, 2020 VW Atlas
Man that sucks, I know how it goes though. Even if that's the case I like to ask the service manager and the most important person they let me talk to "does this make sense?" If they say yes I won't die on that hill but I'll know they're either dishonest or dumb!!
PWillette
Parrie
Maine
I'm not surprised. Is probably dealer dependent, some are easy to work with, some are not.
bodean
Shawn
Alberta, Canada
76 Mini, 99 4Runner, 07 FJ Cruiser, 16 Tacoma
This thread has been pretty quiet. We seem to be pretty deep into winter. Almost seems like this may be fixing the vast majority of the issues...
Off road enthusiast
Agi
New York
2021 Ford Bronco Badlands
That or Bronco owners are giving up, and accepting the fact that there is not a real fix at this point.
bodean
Shawn
Alberta, Canada
Certainly a possibility, wouldn’t be very B6G for them to be so quiet about it though.
JawnyBronco
DelMarPa
2023 Bronco 4dr
The rattle in my AB tranny comes and goes with the temp plus is easily drowned by my Spotify play lists. Waiting for solid results before pursuing a repair.
Geo
Geo
Ford Mustang
Dropped mine off 4 weeks ago. Several reasons why it's still there....main reason is holidays and there's only 1 transmission expert and he has several Ford transmissions torn apart.
Off road enthusiast
Agi
New York
Well, I am on my third transmission, last one the AB version. The noise has returned after 3 months. I know that this is the most “updated” transmission available for my Bronco. I called the dealer and they said they’re not sure what to do since I already got a new transmission just a few months ago, so once and a while I check this forum to see if Ford will come up with a miracle transmission that doesn’t make noise.
