Much to do about Crashbars
Daktari
Oliver
As a mechanical engineer I'd say "Too many variables to tell", but I can see in this shot that the jeep wheel appears to tuck under the body possibly triggering the weight transfer that results in the eventual roll. 🤷‍♂️
Yes, also the Bronco wheel seems to just fold in a lie flat against the body. Plus the Bronco has more 'stuff' on the left side there, Jeep pretty much has only the flimsy fender and a bit of the engine compartment there. Shaped like a boat.
abe
Abe
16 F150 XLT 2.7 (sold 😥), 84 Chevy K5, 09 Chevy T
I wish some of y’all could ride in my old ‘78 1/2 ton on 12 in skyjackers and 38 buckshot mudders and ask if removing a 4 inch piece of metal on a modern vehicle was safe.
I haven't seen a set of Buckshots in years. Well done!
kodiakisland
Arkansas
We were lucky to live through that. Absolutely no wet highway traction in a vehicle that could barely stay in the lane at 50mph. Those were the days.
abe
Abe
Sounds like my K5 with no power steering on Wild Countrys. It also pulls hard right if I have to slam the brakes. I've been lucky more than a few times haha
kodiakisland
Arkansas
I kept the hubs locked year round in my K5s as it seemed to tighten up the steering somewhat.
Yours had brakes?
  • Haha
Reactions: abe
Pkrpro19
Jaxon
Panama City Beach
BMW X5 M Sport, Mercedes Benz E350, Bronco Raptor
I get that. But how thick is the gage? Hollow steel and still weigh a decent amount. Have you removed them? Do you know how thick and heavy they are? If you have please share.
Its basically a 1"x1"x6" hollow metal bar. It wont affect anything at all.
Bradley Thornton
Bradley
Hattiesburg MS
18 Sequoia TRD sport, 2021 Badlands Sas, 93 Cobra
Said this earlier I think this maybe the reason for the aluminum front lower control arms.
H - 2 CHARLIE
CHARLIE
So cal.
F 150 - E 350
One can only hope the head on is a Mini copper or a Geo Storm . Driving is risky alone ,texting and driving is 5 times more risky .
NotApplicable
BEVs
@Russ.Gil I know you know this, but no one on here has anything remotely resembling the credentials necessary to speak to the qualitative or quantitative protection offered by the crash bars.
Amateur welders be up in here pretending they’re materials scientists and physicists, prescribing you some veterinary meds while they’re at it…
JohnnyBronco
Pennsylania
X4
Not really worried about "tipping over" it was more a question of do they add weight to help keep weight on wheels. I've heard some people have found like 50lbs pet rocks in their jeep installed by manufacturer or aftermarket to keep the center of gravity lower. Was more a question of "do these have a dual purpose."
You must be thinking of LR3/LR4 which had hanging corner weights. Each weighs more than all the "crash" bars plus 2 bumpers.
These hollow tubes are being called crash bars and if Ford actually labels them as such in the parts catalog it is amazing. They look to me instead to be part of the assembly process, big giant assembly crane holds body by the bars and lowers into frame, after which the "assembly" bars are to be removed and recycled.
The ones in front of step look like a good place for Gobi to mount the front of their rack. The ones behind the bumper look like a good place to lount lights.
I have never seen such bars on any other vehicle. If any have them they are hidden by or incorporated into bumper or body
rugbysecondrow
Pauly P
north carolina
1964 C-10 stepside
You're over thinking this or don't understand how they work.
It's a steel tube that's less than a foot long. Go under there and look. I think it was a 13mm socket that is needed. The bolts were torqued so take a breaker bar too.
I spent some time looking at them while I was working on a light bracket (the two bolts make a great mounting point by the way) and am impressed with the simplicity of the design. Its not the weight that makes them useful. Their shape, position, bracket mount, diagonal support, etc. is genius.
I watched crash tests (on here someplace) and wondered how the impact energy from a frontal collision would push the car sideways (good thing) to keep the energy from going all the way into the cab. Looking at the entire design shows how they work. Its a series of collapsible sections that would force an intrusion out as they collapse. Its really quite simple.
Good job Ford. I'm keeping mine.
I can also see how a tapered one would be beneficial and still work to some extent if it was clearanced for a larger tire.
This. From the accident photos I have seen, the bars have functioned as intended.
I don't know the counter factual (if they are removed) nor have I seen comparisons.
MadMan4BamaNATL
Ray
Atlanta
Anytime. I get your perspective. I’ve got 3 daughters myself and wanted to feel good about it before removing the bars. I’ll probably snag aftermarket bars this year. Also, I put 33s on my BD without a lift and had the most rub with the rear bars, especially in reverse. Rubbing with front bar was minimal. Rear bars need to be tapered to avoid rubbing or just get a big enough lift where it doesn’t matter
This ain’t a call out against you in the least bit, so I don’t want you to internalize what I’m writing, as I‘ve got a family just as everyone else, but if keeping the 3 (or however many) daughters or sons absolutely safe were the top priority (should be), then the best thing for them is for dad to not even own an off road vehicle since going off road and playing in the woods is dangerous!
If dad (any dad) were actually only buying such vehicle to run them to soccer practice and school, or road trips to the beach, then the Bronco should never had been on dad’s radar to begin with.
The Explorer is much better and safer in every aspect than a high centered, heavy, truck framed, Spartan, off-roader.
So, let‘s just be serious here, the Bronco never has been and ain’t now about safety, it’s about fun; and dad taking the girls out for some wheeling fun, camping, and hiking, are equally important to their development. They’ll grow up stronger, more confident, and more capable than if you only kept them cooped up on the pavement and on the couch eating.
Safety is relative and since none of us can have it all, we try to balance what’s safe, vs, what we enjoy.
The Bronco isn’t the best for some soft ass adults or soft ass kids. However, for the adventure crowd who‘ll take our chances along with some bumps and bruises along the way, well, this damn machine and others like it may as well be a safe bubble. Other option is a horse and they have thier challenges as well.
BOLD Renegade93
Bossier City, LA
2021 Ford Bronco Black Diamond
Yep. Well said. As weird as it sounds, keeping them as safe as humanly possible just isn’t realistic. They aren’t going to live in a bubble or avoid all risks that might result in injury. That’s part of life. Life is full of decisions that require us to balance risk vs reward and it’s up to each of us to make that assessment. I make a living flying a 61 year old airplane because I felt the Air Force was where I wanted my career to be. Definitely not the safest career field out there but I felt like it balanced out the risks of flying/military service and offered me high job satisfaction and a comfortable financial situation for the family. That’s obviously just one of many situations the fine folks at Bronco 6G will be in, but we all have to make the call we feel comfortable with.
I knew the Bronco wasn’t the safest vehicle out there, but it’s not an unsafe motorized coffin. I was comfortable with that decision. Thanks for the input
Southern Girl
1974 Bronco/2024 Wildtrak
This is the only picture I have where it's not covered in mud. Zoom in and all of your questions will be answered. The mysterious crash bar seems to only be a barrier to me getting mud flaps.
Ford Bronco Much to do about Crashbars 1642265873981
Nolabel
Van
Mesa Az
See. I have no problem with that for MY safety. But keeping my daughter safe is more important to me than anything else in the world. She's all that matters. So you say you "wish we could" I say let's do it but not with my 15 month old daughter.
Unless your daughter is down by your feet in a crash where those are placed. I'd venture to say it'll be ok.
