- #16
Corporate cover ups and conspiracy theory's aside, I doubt Ford is ever going to come out with a better explanation let alone one good enough for you to believe it. Like I said, this post was just to pass along information that I saw posted, if you want to keep putting 7 quarts in your bronco, more power to you.Why is the factory fill a quart higher than any other 2.7L Ecoboost application if the engineers didn't intend to run 7 quart service fills for durability and the off road performance targets?
Why would you also again have them say that running 7 quarts will not harm anything, but if it was supposed to be 6 as they claim then they are massively wasting money on the factory fill even at corporate negotiated rates for bulk oil purchases?
This reeks of corporate bean counters trying to save a penny on providing the correct dip stick for the 7 quart service fills even if it will cost more in warranty work for those who followed the reduced oil level and subsequently lost an engine due to oil starvation and then Ford eats the warranty cost.
The dip stick is potentially correct at a 6 quart fill, but it is incorrect for the original service fill of 7 quarts as was in all of the documentation until they issued those ssms to try and cover up the wrong dip stick.
The people who actually built the engine specifically fill the Bronco's 2.7L with 7.5 quarts vs the F-150, Edge, etc at 6.5 quarts.
You'll never get 1.5 quarts of oil retention in this engine, more like 0.5 based on these factory fill to service fill differences.
I also see how you're ignoring the fact that they don't say never run 7 quart service fills, but to say that it's okay to ignore the max fill mark on the wrong dip stick because it won't cause any harm, so ignore the manual's warning on that. The FT4Z-6750-A part was for the fwd based 2.7L Ecoboost at 6 quarts. FT4Z-6750-B/C are also 6 quart sticks on a 2.7L, the F-150 has another different 6 quart stick, but those applications are supposed to be at that level. All of the previous documentation and consulting of the field service engineers have put the Bronco at 7 quarts until they realized that customers were looking for a dip stick that accurately reflects the original service fill level and were trying to buy the corrected 2.7L dip stick that they now try to claim was only meant for the Bronco Raptor's 3.0L, but that's not entirely true either.
So no I have not been given any valid reason to believe that after everything they did to make the engine prepared for the off road application they really intended it to hold only the same amount of oil on a service change as any other 2.7L application.
Unless they have an actual valid engineering reason for the change and it comes straight from the team validating the engine this sounds more like oh shit we need to change the dip stick on the 2.7L Ecoboost in the Bronco, it's really showing over filled from the factory and with the service fill, so the engineering team orders new dip sticks that read correctly for the 7.0 quart service fill but were overruled by the bean counters/accountants and lawyers to say that they will have the documents changed instead to match the parts in use, but you can keep the factory fill the same, that we don't care about.
