About 1/2-3/4 inch.Not sure if this was covered but I purchased suspension off of a non sas BL . Both vehicles are 2.3L , 4 door no tow. his vehicle is a manual and mine auto. What do you think an estimate in height difference will be?
I did exactly this same swap on my Bronco 2D 2.7 OBX to 2D 2.7 non-sasquatch BL suspension.May try a leveling kit which may not completely level me but could make it look as it should . Thanks for replying.
No real difference between manual and auto for the purpose of suspension.And this is the same situation manual trans suspension on an auto vehicle ? Looks good
Everything is the same for those 4 parts as far as I know.Anyone know if these components (top hat, Isolator, nuts) are same on SAS, non-SAS, and Hitachi?
Didn’t think I needed a lift on my black diamond to fit 33s??
So all Id need on my 2dr is at least 2.5 in for 37s
eibach it is then
Did you?Didn’t think I needed a lift on my black diamond to fit 33s??
That’s right. I thought 33s would fit and I thought others on here said the same at some pointDid you?
Im a newbie when it comes to suspension works, Im trying to learn so forgive me if I seem ignorantThat’s right. I thought 33s would fit and I thought others on here said the same at some point
before
after
Well good news is that you don't even need a lift to run 33" tires. I have seen stock OBX run 285/70R18 Ridge Grapplers with the stock offset rims without pulling the crash bars. With +30 offset 17x9 RTR Tech 6 rims, I was running 295/70R17 MT's (33.5" tires).I have read thru many pages but not all 31, frankly it has made my headache worse.
I have a Black Diamond, 2.3, 7mt with tow package. I only want a 2” lift and will replace with 33’s when mine factory tires are shot.
I will not use spacers and don’t want to go the puck route.
What is my best alternative without sacrificing off road performance?
Thanks.
