Underground Graphics
Greg
Houston
www.undergroundgraphics.com
22 Bronco, 20 Jeep Gladiator
Does anyone have the part # handy for the upgraded rack and tie rod assembly mentioned which is used on the WT and Braptors?
I want one too, ...these are gonn be selling very well i'm sure.
RHeinz
Ric
Houston, TX
OK, I’ll take a shot at this.
BSME ‘73, with one semester of metallurgy, way back when. Did a study and paper on a crankshaft fatigue failure.
Opinion (and feel free to disagree ): The “dark area” of the failure appears to exhibit ”beach marks”, typical of a fatigue failure. It appears that it has been failing for some time now, otherwise it would be shiny. The bright grainy area was the ultimate separation/failure. The bend kind of contradicts the fatigue failure theory, unless it was bent initially, either new or very early on. Looking at my tie rods, they are fairly well protected. You would have to try really hard to bend them on a lift. The bend does seem to correspond to position of the fatigue failure however.
After being bent, it is not a straight “column” anymore and the connection at the nut is in a bending/flexing mode every time the steering is turned. This cyclical bending may have caused the fatigue cracking and led to the ultimate failure.
it would be interesting to “look” (microscopically) at the grain structure in the area that appears to be fatigued. Not sure I would remember what to look for however!
survivormanca
Ron
texas
nothing
@flip do you know how we can order the upgraded rack and what the estimated labor cost is for the swap?
DaBroncstah
DaBroncstah
Hadley
N/A
wow you sound like you know your stuff!!
LSBronco13
Lee
Louisiana
Chevy Tahoe
Well what I thought would never happened happened.
I just got my babe back from getting the recalls done on it and literally not even an hour after having it back I was turning around in my driveway and the tie rod snapped :). I’m completely stock with 33s!
I thought tie rods were only snapping on off roading conditions but I guess not! This sucks
More info/answer:
as I said earlier I’m being completely truthful. No curb smacking has happened unless someone stole it in the dead of night and took it for a joy ride. The dealership idea might be correct though, they did do an inspection so maybe they lifted it up and something happened? I’m not sure but I am sure that I’m telling the truth.
I get where you’re coming from though with being suspicious (people always tell major stories and leave out key details) but I promise I’m telling you everything that I’ve done!!
You mentioned the Bronco was in service due to recall with no off-roading.That damage could be due to lift at the dealer. A tech may have caused enough damage to weaken the rod to its conclusion. If it was a weak metal break that is an easy investigation because a fabrication review of the break can show if it was a manufacturing issue.
Draughon
Daylon
Dallas
BMW 4-Series
Might be the photo angle, but the area that snapped on the tie-rod has a light and dark side to it - that implies that perhaps there was a flaw in the rod itself that allowed it to snap?
Might be talking out of my ass, but I watch a lot of Forged in Fire, so clearly I'm a metallurgy expert. Looks like a cold shut caused the snap - otherwise the break would be all the lighter color.
pjstans
Patrick
Denver CO
Subaru
Anyone think this is unusual? This seems to be rather frequent for something that should be able to take a reasonable amount of off road punishment..I get the extreme cases but this just seems to be a frequent occurrence
DaBroncstah
DaBroncstah
Hadley
N/A
From what I’ve read it’s mostly occurring off-road. i can understand the tie rods snapping under extreme stress but this is just crazy. Thankfully this case is the only one I’ve heard of so hopefully it’s just a fluke!
Giddyup Buttercup
2022 Ford Bronco
Tie Rod support sleeves make more and more sense.
I've been scared away from these by the "it will transfer force something even more costly to replace" voices. I may go ahead and get them put on.
HOW can these break on a driveway even in 4X4??
Just turning around should not have chewed the "grass" up.
STLDAVE
Wentzville, MO
2011 4Runner
If they tied it down then the bend would be up... not down like in the pic....
The bend in the rod seems to indicate the rod was pulled up, not down. This is opposite from what a tie down bend would look like. However, a bend would shorten the effective length of the tie-rod, causing a toe in condition for that wheel. If the toe was reset to factory specs, the rod would have been rotated to make the adjustment which could account for what appears to be an upward bend. Was someone too dumb to realize the rod shouldn't be bent? OR maybe trying to cover up their f--- up?
Just throwing that out there...
DaBroncstah
DaBroncstah
Hadley
N/A
the grass (it’s more like clover ground cover) was wet and the cover on the ground is really thin and delicate and sometimes it gets all chewed up just from me riding my bike through. Usually when I turn in place in the alley way the grass gets destroyed and looks like that!
BroncoB
Christine
Tampa Fl
Bronco First Edition
I think it is more up and back. The ball end would be more indicative. Like this
Ford Bronco Tie rod just snapped while turning around in driveway [Update: Replaced Under Warranty] 1659729397534
