2.3L 7MT — lurching/stuttering in low gears between 2-3k RPM
Bronco Bax
New Jersey
Have about 6k on mine and ive has this happen a handful of times as well
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
It happened to me again the other day out of nowhere - around 10k miles. Hasn’t since.
BCFDLtE13
Wayne
Manchester, MD
2015 Mustang GT Performance Pack
It's happened to me 2 or 3 times also. Each time the engine was not up to operating temperature yet. Outside temperature was around 65 degrees. I usually let it idle long enough at start-up for the rpms to drop from the cold start 1200 rpm to normal 900 rpm before driving. It seems it could be a throttle mapping issue, because it happens in between cold start and reaching operating temp. Badlands 2.3 7MT, about 1500 miles.
Trish
Bellevue, WA
2021 E53 AMG, 2022 2 Door Bronco
Just had it happen to me for the second time. I’ve got 900 miles and the car was definitely at full temp in second gear at 3k rpm.
Bronkers
Ben
Las Vegas, NV
2022 2dr Bronco
Great work getting video. Mine hasn't done it much lately but I'm near 16k miles now and it's already 90 degrees out when I start my day. Will see if I can get it to come back this fall. Did happen after engine was up to 140ish degrees awhile back. Always 1st or 2nd gear around 2,500rpm
@Ford Motor Company
Caught in the act.
kodiakisland
Arkansas
12 Tacoma, 18 Indian, 23 GV70
Just drive it hard til the tranny figures it out.
It's a manual. The tranny just does what you tell it to, like a good tranny should.
NJRoadkill
South Jersey
www.instagram.com
22 Bronco Badlands 2.3l Manual
I’ve had my 2D since January, 5k miles. It’s happened 2-3 time randomly, usually shortly after I start it and get on my way in the morning. When I shifted it went away. I’ve been keeping an eye on it but have chalked it up the ECU learning and not letting it come up to temp first.. It seems very random at this point.
If it continues, or becomes an issue I’ll start the “can not recreate” paperwork.
thesocalexplorer
Joe
Southern California
Same, I've had it happen 3-4 times over the span of 3k miles. Noticing that it usually happens when it's hot out (80-90*F) and the engine is coming to temp still. Not really worried about it at all, I'm chalking it up to be a random cold engine throttle quirk.
Demosouthpaw
J
T A M P A
B R O N C O
Interesting, my 19 GT did this to me a few times, it was mainly when I would downshift and go WOT, in the lower revs. I know the engines are different however; when I took it to ford there were no CELs and when I described my symptoms the service writer told me its the computer protecting the engine.
I have an auto 2.3 BB, and never had the issue you mentioned but, if I do make it down shift around the same RPMs there is a lag time. So I wonder how much is the ECU throttleing for AFR or even the TCS freaking out.
My two cents worth anyway.
DaveInSA
Seguin, Texas
2021 Bronco Badlands 4DR, 2007 Saturn Sky
Mine just did this to me. 2.3L MT. Identical to the video posted earlier.
It was a little cold in that I had just started 2-3 minutes before, but it had only been off for about 30 minutes from when I last drove it and it was at operating temp then. Ambient temp was about 95F when it happened.
2100 miles on it.
Boreal
Colby
MB
www.cspencephoto.com
2022 Badlands 2DR
Another chiming in with the Bronco Buck. Ive had this around 4-5 times now... Usually within 10-15 seconds of starting off when the vehicle is cold, but above freezing at ambient. I wonder if there is something to do with the mapping/tables when coming off the warmup cycle?
thesocalexplorer
Joe
Southern California
@Lakelife36 - Here's another thread with the same 7MT issue (y)
Lakelife36
Ben
Interior of BC
Caught in the act.
I'd say that's the same as what mine does too, so far in second gear with medium throttle at around 2800 RPM when the engine is not quite up to temp.
Did you have any luck with FoMoCo offering help?
