Manual transmission scraping noise / grinding sound
UM_Ftown
98 5.9, 01 XJ
Ford has sold 162,250 Broncos so far (2021, 2022, 2023).
The manual model's take rate is impressive at roughly 15 percent.
162,250 x 15% = 24,337 (and a half!)
Out of 24,337 manual Broncos how many of them have the grinding noise?
Is it 0.1%, 1%, 10%?
Don't want to hijack or derail this thread but do you know what % take rate the Wrangler has for Manual? I feel like the Gladiator is 1%, I bet the Mustang is even less than 15%.
gtabert
Greg
Woodstock, IL
'18 gt350r / '65 f100 / '99 Silverado / '15 VW TDI
"halfway into 2nd" is not a proper way to shift. Synchros only move in one direction. The shift sleeve contacts the blocking ring 1st. The purpose of the blocking ring is to act as a brake to match the rotating speed of the 2 components. Once speed is close enough, additional pressure can push the sleeve onto the gear (the "hard part"). If you "limp wrist" your shifter so that you only catch the blocking ring, but not completely lock the sleeve to the gear, then yes it's gonna grind...don't do that. If you are 100% sure that it's all the way in gear, and it has a tendency to "pop out" of gear and grind, then the issue could be internal, or cable adjustment. There are detents that hold the fork in place once fully engaged. They are generally just a ball w/a spring behind it that catches a groove in the rail that the fork is pinned to. Sometimes the spring breaks...but usually that's after LOTS of miles. They are easy to hear if you listen to the trans underneath (with the vehicle shut off and parking brake set), Have somebody shift all the gears while you listen. Should be a nice solid click sound for each. W/the cables off the trans, you can feel them moving the levers by hand (this is how I check after re-assembly of a manual trans). Here's a pic of what the lever positions are:
Great write up absolutely correct. I liked the old school mechanical Hurst, it was easy to feel every nuiance, that's where my knowlege comes from 60's know how. Todays stuff is not as much fun, maybe because I do not have any of the electronic diagnostic equipment. The MT is perhaps the most analog of any part in these newer vehicles. Still basically the same as old school.
Bmadda
Wisconsin USA
1990 Bronco eddie bauer
Definitely when they started using cables it took some of the "feel" away, but if you know what you are feeling for you can still tell what a MT is doing by "feel". The cable shifted ones have improved by leaps and bounds in the last 20 years or so. My 6G is one of the best I have ever driven!
huey
kevin
Ontario & Kentucky
VW GTI VW EOS GMC Envoy Badlands Bronco
CapeCodCash
T
Cape Cod
23 Bronco and 14 Raptor
I would agree with you. Mine is there most the time. The warm up idle it's always there regardless of temp it seems. If the vehicle is a little warmer I only hear it at slow speeds but goes away during regular idle. But move slow in low gears and it scraps
Me too. Mine is behaving the same way. I've only had it for 3 days - 150 miles on it.
I3lackRose
Justin
Ohio
Dropped mine at the dealer last night just cause I wanted them to hear it at it's worse on a cold start this morning. Had 6 service guys standing around my Bronco all like WOW that's wild! Noise is that bad. Service manager even went under it as he was astonished it made that much noise in idle.
Funny story.
3 days, No call back and was told no loaners available with a wait in front of me to get one and no ETA. they saw my Bronco sitting there this morning. "SIR someone returned a loaner we can get you in it" great..... The loaner was a brand new Explorer with 6 miles haha so that's nice but also clearly it's not a returned loaner. Anyways I a will provide you all updated as soon as I know. At the moment they won't open it till the TSB parts arrive in March some time they said but it's clear I likely have other damage in there in addition to anything the TSB will replace.
red.radar
Steven
Upstate SC
2022 Ford F250, 1978 Ford F150
I see where your heading but what concerns me is that there are people with multiple repeat failures. which would indicate a higher failure rate is present.
we could be looking at a driver behavior that is influencing the condition. Maybe this transmission needs to come up to temperature for a while and needs a specific break in procedure to seat things. I don’t know I believe that but you need something like that to be true or a production lot issue for the failure rate to be minimal as you suggest.
I am just waiting patiently for the root cause analysis to be reported Before I get to twisted up about things.
Tricky Dick
Dick
PNW
www.TD-Distributing.com
It can't be entirely ruled out, but at 100 miles like some have reported?
Ogre
James
'23 BD 2dr 7MT CG, '18 Indian Chieftain
If it was driver error causing this for this many people it would still be a design/ engineering fault. It's a mass production vehicle. That means the masses should be able to drive it. And the manufacturer is responsible for providing applicable operating instructions.
I highly doubt anyone without significant experience driving manuals is buying a brand new $40k Bronco with a manual.
I3lackRose
Justin
Ohio
Yea I don't know what driving behavioral condition would prompt a trans to get this way right off the lot and not this widespread. Also plenty of instances where drivers have reported 7,8,9k before the noise started up on theirs. Vast majority start early on it seems though.
CapeCodCash
T
Cape Cod
Why would you doubt that? I have 30 yrs driving stick. I noticed the grinding at mile 19….
BigHoof
PA
Ram 2500
Has anyone with the noise tried a different fluid? The Mustang guys with the MT82 seem to love the BG stuff and say it makes a world of difference.
TxBronc
Tx
72 bronco,2006 Tacoma,
I’m 250 miles and hear noise, not two bad yet, but not promising.
Bmadda
Wisconsin USA
Think we are all too scared to 'cause of warranty. @Bikeric has an MT that has no warranty, but I don't think he's heard the noise yet?
I3lackRose
Justin
Ohio
117 pages. Yup been tried.
