In this application the 2.3 isn't getting better mpg. In some cases it will get worse mpg than the 2.7. Generally people chose a 4 banger for economic reasons, but in this case besides a few grand upfront there really isn't any.There are definitely things you lose. To say you aren't is just plain wrong.
However, depending upon where and how you are going to use you Bronco will determine whether or not these things will matter to you or not.
Both engines are capable and worthy for particular fits. You have to decide which is best for your uses.
If you go with the 2.3l you will get better mpg, so for some that will be important, as an example.
Hills, passing, wind, towing, high altitude, etc. the 2.7l is the better option. Electronic brake boost, trail 1-pedal drive, more Hp, substantially more torque, etc.
You alone know why your buying a Bronco and how you plan to use/drive it and where.
